Sheilding gas flow problem
发表于 2021-9-1 00:03:45 | 显示全部楼层 |阅读模式
Hey guys I'm having an issue with my snap on mig welder. Im having a problem with it acting like its not getting sheilding gas. I just put a new regulator on it and that helped. But I got to turn the pressure way up to get it to weld right, this is making my tank run out pretty quick. Any ideas? ThanksRyan
Reply:I assume that you've checked your entire system for leaks, even inside the machine (remember to unplug when you're in there!). Also, make sure that your nozzle is clean inside, and sealing to the gun properly.
Reply:Yeah iv checked all that I'll have to go back and go threw it again.
Reply:Check the holes in the gas diffuser.  JGSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-23 21:37 , Processed in 0.068406 second(s), 18 queries .
