Welding 3/16th with a Forney C5 question.
发表于 2021-9-1 00:03:35 | 显示全部楼层 |阅读模式
Im welding 3/16th and maybe 1/4" steel brackets to quarter inch tubing. Im using a 220V 180amp Forney C5 arc welder. AC. What size electrode and amps do you recomend?
Reply:quarter inch tubing means wall thickness? either  3/32 6011 , start at 65 amps, or 3/32 7018ac, try 85 amps..
Reply:Originally Posted by weldbeadquarter inch tubing means wall thickness? either  3/32 6011 , start at 65 amps, or 3/32 7018ac, try 85 amps..
GMT+8, 2025-12-23 21:37 , Processed in 0.070897 second(s), 18 queries .
