anchor bolts plastic caps or plugs
发表于 2021-9-1 00:03:34 | 显示全部楼层 |阅读模式
Ive seen some ornamental guys use anchor bolts plastic caps on their 4"x4" base plates around the railing post and was wondering where I can buy those anchor plastic caps or plugs that cover the whole entire 3/8" anchor bolt and nut.   Do any of you use them or know where I can find some?  Janson and King metals doesn't sell them.  Thanks ahead of time
Reply:I think this is what you want!  http://www.mcmaster.com/#bolt-caps/=ffmb4iAEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:Thank you for the tip, forgot to check mcmasters, they have everything lol.    .75 each, spendy little suckers!  pack of 10 is 7.50. maybe stick with painting.
GMT+8, 2025-12-23 23:20 , Processed in 0.095889 second(s), 18 queries .
