I was wondering if a sga100c with spoolmate 3035 off of a bobcat could be used to weld light steel? I know it's probably not ideal just hoping it would hold me over while saving for a suitcase. Thanks in advance
Reply:It will work just fine, but it gets expensive constantly changing out the 2lb wire spools. some guys have made spool rewinders to use 44lb spools and to refill the 2 lb onesTiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Can't see why not. Miller lists the SGA100C and 3035 as Bobcat compatible. I plan on eventually getting an SGA 100C to go with my 3035 once I manage to arrange a time to pick up the Bobcat I'm getting.http://www.millerwelds.com/pdf/spec_sheets/M1-5.pdfI've used my 3035 with .023 and .030 wire and FC for welding racks on trucks since it's got more reach than the gun on the MM185. The only thing you'd have to watch is how hot you run that small gun. It's rate at 150 amps @ 60%. As long as you aren't running tons of heavy wire thru it at high amps it should work just fine..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Adding the HD barrel to my 3035 can I really run that thing up to 200amps? And thanks for telling me about a rewinder would have never thought about that.
Reply:Works awesome used to weld SS tankers with oneAnother day in paradise You only have to be smarter than the metal". WeldiniMaking an honest living is nothing more than stealing from someone who can afford it and everyone feels good when it's over . Weldini
Reply:Originally Posted by JwmettsAdding the HD barrel to my 3035 can I really run that thing up to 200amps?
Reply:+1 more. All good info. AAmetalmaster is the master when it comes to these. I converted mine to the standard miller mig tips after reading his post on it and it works great. I have run mine off my TB and run FC, solid wire, SS, and aluminum out of it and it works great. |
