What are the advantages of laser welding machine compared with argon arc?
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-10 16:47:20 | 显示全部楼层 |阅读模式
Handheld laser welding machine is a very popular automatic welding equipment in recent years. For many manufacturers who are still using argon arc welding machine, laser welding special equipment is a new thing and new technology. If you want to use laser welding machine technology, but you don't know the specific situation, today's General Electric editor will explain the main advantages of laser welding machine, For the manufacturers who are still in trouble.
The appearance of products produced by laser welding machine is more beautiful
First of all, the beam quality of the welded product is stable, the welding is firm, the welding seam is smooth and beautiful, and the heat adverse effect area is small, so the welded workpiece basically has no deformation, no welding scar, and does not need the secondary grinding process. For the enterprise manufacturers, it actually saves time, improves the work efficiency, and reduces the labor cost.
The laser welding machine has faster welding speed and higher production efficiency
The laser welding speed is faster, 5-10 times faster than the traditional welding, the penetration is relatively deep, and the welding yield of different materials is high. Moreover, it is equipped with special equipment for cold water, which can ensure continuous operation for 24 hours.
Energy saving, consumption reduction, safety and environmental protection
Laser welding energy saving, green, safe and more environmentally friendly, the traditional argon arc welding machine will cause a lot of welding dust and residue, which is more harmful to the environment, while the hand-held laser welding machine has less impact on the natural environment.
Simple and easy to learn, ordinary people can operate without a license, help enterprises improve efficiency, but also save labor costs
Take argon arc welding machine as an example. A mature and stable welder must have a welder's certificate to work, while a hand-held laser welding machine only needs an ordinary operator. The labor cost of a mature and stable welder with a welder's certificate is higher than that of an ordinary operator. The operation of the hand-held laser welding machine is simple, You can weld beautiful products without experience and teachers. The welding speed is faster, 5-10 times faster than the traditional welding process. A laser welding machine can save at least 2 welders a year.
Low loss, long service life
The consumption of consumables is less and the service life is long, which can meet the needs of long-time welding. The general electric handheld laser welder basically does not need the cost of consumables. The service life of the pump source is up to 100000 hours, and the daily maintenance is basically free.
Hand held laser welding equipment can be used in hardware products, sheet metal, chassis, water tank, distribution box, cabinet, kitchen and bathroom, furniture and household appliances, stainless steel door and window guardrail, advertising signs, process products, battery components, steel furniture, shelves and other major fields, as well as seam welding, fillet welding, butt welding, inner fillet welding, vertical welding, etc. In material, the laser welding machine can be used for welding aluminum, iron, stainless steel, copper and other metal sheets of the same material. As well as aluminum copper, stainless steel, copper and other mixed materials welding, covering the field is far more than the traditional welding method. These main advantages are not possessed by traditional welding
Guangdong Pudian Automation Technology Co., Ltd. is a professional manufacturer of welding equipment. For 16 years, it has focused on R & D and sales of spot welding machine, laser welding machine, non-standard automatic welding machine, welding robot and other welding equipment. Pudian welding machine focuses on the field of metal welding, saving energy and reducing consumption, improving welding quality and improving welding efficiency, Reducing the cost of welding is our fundamental service to customers.
Free proofing hotline: 13631767737
GMT+8, 2025-12-18 08:56 , Processed in 0.063515 second(s), 18 queries .
