Trailer ?s
发表于 2021-9-1 00:03:30 | 显示全部楼层 |阅读模式
so i want a flat bed/ car trailer, was about 2 days from going out to finace a brand new pretty one when i scored on a 27 foot triple axle boat trailer. So since i like to use my welder and just got my frist little shop to work in ill convert it over. I want to build about a 18 foot trailer. the boat trailer has the hitch brake setup on it going to 2 of the axels, should i keep this or ditch this brake setup. im only gonna run 2 axels, with the 60/40 setup. How far away from the tounge should the trailer deck start? ill post some pics tommorrow.lincoln weld pac 100Hobart handler 120Lincoln  "BuZZ box"Lincoln Precision Tig 225
Reply:Don't know how everybody else does it, but I generally measure from the ball to the end of the bumper.  then I make the tongue a couple inches longer than that.My name's not Jim....
Reply:About the brakes, what kind of shape are they in? What do you see when you take the cap off of the master cylinder on the tongue? Is there any fluid, is it dry, is it rusty? What about the brake assemblies at the wheels, are they in good shape, or rusted beyond all recognition? With surge brakes, you don't need a brake controller in the truck, plus you have the option of using disc brakes. Used boat trailers almost always need total replacement of master and wheel cylinders, if not entire wheel brake backing plates, because the rust eats everything alive.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:sorry i didnt get the pics yet been busy moving **** in my new garage. everylooks like its in good visual shape the trailer has very little rust on it so im hoping all is good.  thanks for the replys and ill try to remeber the pics to show u guys what ive got to work with.lincoln weld pac 100Hobart handler 120Lincoln  "BuZZ box"Lincoln Precision Tig 225
Reply:lincoln weld pac 100Hobart handler 120Lincoln  "BuZZ box"Lincoln Precision Tig 225
Reply:theres a coulpe pics, im worried about havin to move the axels since the trailer cuvres in towards the tounge. im weld some 5 inch channel to box the front in some and mount the axels on. or im just thinking about using that 6inch 6 channel to build a whole new frame.lincoln weld pac 100Hobart handler 120Lincoln  "BuZZ box"Lincoln Precision Tig 225
GMT+8, 2025-12-23 21:39 , Processed in 0.103696 second(s), 18 queries .
