Skateboard Rail
发表于 2021-9-1 00:03:29 | 显示全部楼层 |阅读模式
Here's a few pictures of a skateboard rail I made for my son from some 2x2 square tubing. These sell for over  a 100 dollars if you buy them from dealers. The only cost for this rail was a little mig wire and shielding gas. All of the materials were given to me. Attached Images
Reply:Looks nice.  I might add gussets to the base, depending on how hard he's hitting it.  But then, my skateboarding references go back to the era of half pipes and swimming pools.Jack OlsenMy garage website
Reply:We used to call those "trip wires" because you would always trip on the flat coming out before you got to the rail.  Take it from a former "skater" (i'm just too old now) the best thing to do here is extend the front portion enough that by the time he is on he will be far from the "trip".  Another thing we did was make a square with four rails . it was heavy but you would not trip for the newbies.  Hope i was clear?
Reply:Are you planning on bolting it down? It looks like it might slide. Good thing it was cheap, the hospital bills won't be. Then again kids are made of rubber. I can't believe all the stuff I got away with.
Reply:Sliding does'nt seem to be a problem so far plus he wants to be able to move it around to different spots.
Reply:On the side of safety I would close up the end of the tubing and gusset the uprights.
Reply:I really like the post lintel construction aspects of the project.
Reply:Looks good, how about some action pics?
Reply:cap the ends I have witnessed kids slam the ends and  without caps it could be nasty. You dont even need to weld them though I think they sell plastic end caps at home depo or lowes that press right in to 1x1 tube
Reply:Just another worthless safety suggestion..At each end, weld a 30 degree down canted piece almost to the ground so you're less likely to bang into the squared end and donate plasma.Sorta like this
Reply:Wannabe said"On the side of safety I would close up the end of the tubing"Isnt this one of the reasons they make duct tape,four or five wraps should save a kid from  a lot of skull diggeryFelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:definatly put caps on it . we cemented the posts in buckets worked really good  and two guys could move it around was less to run into
Reply:^^-- I like the idea of dropping the posts into cement buckets .... also Viper's idea of the canted rail ends.
Reply:Unfortunately I don't have pictures, but I built one virtualy identical to the "blue design" above.I riveted pieces of timing belt (tooth side down) to the bottom of the feet. no sliding problems after that.Don't talk about it, Just do it!
Reply:Nice work man.   I did this one for one of my skater friends.   It stays in place just fine.The rail is 4x2 tubing, the ends are capped. browndogwelding.com@welderassassinMy Blog on The Fabricatorfacebook.com/BrownDogWelding
GMT+8, 2025-12-23 21:37 , Processed in 0.098468 second(s), 18 queries .
