More handrails
发表于 2021-9-1 00:03:26 | 显示全部楼层 |阅读模式
I just finished up on a single step center rail today... I did a little math on autocad and found my lengths and angles.  I glued the top part of the rail together and cleaned it before adding the supports to make things a little easier.  Then I drew out the bottom pads with 6" extra on each end of a strip so I could roll them to the step face radius's.  After a quick sheer, I had only a little sanding to do because I incorporated the corner radius's in the burn along with the holes.  To make sure things were true, I did the math to figure out how far to shim the rail up to meet the middle of the pads.So far I'm into it about 3 hours or so (blending welds take quite a while on the insides)I'll try to remember to  post the finished and installed rail. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-23 21:36 , Processed in 0.096774 second(s), 18 queries .
