Apprenticeship Test.
发表于 2021-9-1 00:03:15 | 显示全部楼层 |阅读模式
Hey everyoneI just wanted the forum to see my apprenticeship test project, which gave me a "C+"The "legs" are only for show, the actual "legs" are way longer.and its me on the left, in the last picture  Attached Images¤If you got money, i've got time
Reply:Hi, Nice strong looking job my friend. the welds on the twisted spindles looks too cold. what reason did you get for the marks you received,  Best regards  Gordon.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:The fence looks very nice.  What is the base for?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Looks like more than a C+ to me. I think you did well, myself.
Reply:Originally Posted by DesertRider33The fence looks very nice.  What is the base for?
Reply:Ikke så dårlig! Skoal!Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Jamen tak skal de have  ¤If you got money, i've got time
Reply:HGHS-corp,  The design of the project is very nice looking. Everything looks well laid out and "straight". As for weld quality I can only see a few examples. Some look fine, others not so much. As Gordon mentioned there is lack of fusion present. I would also be interested to know if there were any remarks included with your grade. Were you graded on blueprint reading, fabrication, as well as final product or just graded on the final product?jrw159 Attached Images
Reply:Originally Posted by jrw159HGHS-corp,  The design of the project is very nice looking. Everything looks well laid out and "straight". As for weld quality I can only see a few examples. Some look fine, others not so much. As Gordon mentioned there is lack of fusion present. I would also be interested to know if there were any remarks included with your grade. Were you graded on blueprint reading, fabrication, as well as final product or just graded on the final product?jrw159
Reply:HGHS-Corp,  I am no structural/mechanical engineer so take this with a grain of salt. I would agree that there is most likely plenty of good weld on the areas mentioned (that can be seen in the pics provided) that it will not fail. It appears that the lack of fusion is not all the way around, only in a portion of the weld. However it is still a rejectable flaw and this most likely had a bearing on your grade. Based off of what I can see and the added info you provided I feel that it is a C+ for sure and I may have given a B grade (assuming the lack of fusion is limited to the areas show) . Most importantly I would have informed you of why I graded you that way so that you could fully understand and apply that info to future projects. I am not sure what your background is but if this is one of your first projects I would say you did well as long as you learned from the experience and apply the learned lessons in the future. All in all, from what I can see, pretty good! Good luck with the next project.Best regards,jrw159EDIT: FWIW I have seen worse welds on more critical things made by people far more experienced than yourself.Last edited by jrw159; 10-03-2009 at 02:31 PM.
Reply:Looks good from what I can tell.  I can't tell you if the welds are right or not as I am new to welding myself.  I do have a question about the scroll work, are 3 of the scrolls up-side-down?  Or is that by design?  Keep up the good work. Attached Images
Reply:bartels_metal_works,  DAMN good eye!! This may have played into the final grade as well.jrw159
Reply:Well spotted on the scrolls Bartels_metal_works Sometimes you cant see the wood for the trees, All in all very nice job, still stand by my original post, a little more heat to a few of the welds would lifted it to the next level.mentioning distortion control I think is reasoning after the fact,Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:You deserve way more than a C+ i thing good job.safety last
GMT+8, 2025-12-23 21:41 , Processed in 0.068723 second(s), 18 queries .
