Borrowed a prject from here, Thanks
发表于 2021-9-1 00:03:15 | 显示全部楼层 |阅读模式
did a little addition to my welding table thanks to the forums, thought i'd share. Bought a bumper style reciever from HF on sale for $10. Bolted to the table. I welded some 2" channel with 3/8 plates on top to accept the vises. Drilled holes to drift through the reciever and a done deal. I welded some 2" inside stock to the bottom rail of the table to store the vises. A nice little project, thanks to the forum, and a pleasure to get the vises off the top of the table. Attached Images
Reply:borrowed from here as well Attached Images
Reply:Nice job 246, could just do with changing the mounting bolts for countersunk allen screws,keep the bench top flush.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:This is an idea a lot of us will be incorporating into our tables and one I plan to put on my next  table build.
Reply:Nice job on the bench attachments 246.I'm with Gordon though on the countersunk bolts if you don't want to weld it permanent.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice job on the hitch, and I'm with them --^^ on countersinking the bolts.  I also like the idea of "storage" underneath.  Harbor Freight receiver hitch, hmmm ? ..... *starts thumbing through this week's ads*
GMT+8, 2025-12-23 23:22 , Processed in 0.253893 second(s), 18 queries .
