Modified Welding Cart
发表于 2021-9-1 00:03:08 | 显示全部楼层 |阅读模式
Ive always had my stick welder on this old junker orange cart. it sucked. you had to move the welder as if it was on a dolly. it had feet on the front so i had to tilt it back and roll it, pain in the butt for tight quarters...and really heavyfirst i cut the feet off and put swivel casters on it...then i added 4 hooks, 2 on each side to keep the cables seperate and untangled..and finally i made a sort of angle iron base on top to sit the Lincoln and have both welders on one cart !nothing fancy, but its alot better then it was. I ran out of black primer so i will finish that up soon, L-Tec Heliarc 250hf squarewaveCentury AC/DC 250A Stick Lincoln WeldPak 100
GMT+8, 2025-12-23 21:41 , Processed in 0.115142 second(s), 18 queries .
