pull behind trailer
发表于 2021-9-1 00:03:04 | 显示全部楼层 |阅读模式
what do you guys think about customizing a pickup box trailer or flat bed as a welding rig im sure someone has done it i suppose you could use a 2wd in summer and 4wd in winter or hard to reach places and get better mpg what are some thoughtsmiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:there are quite a few on here maybe try a search of welding rig.
Reply:Hey mn welder,Is this what you are thinking about?My rig is set up for general repair & not a pipeline, rig, or structural unit. I work the construction sites, housing plans & developments, farm, & classic/show car restorations in the field. My truck is 4WD & is necessary quite a bit in the winter & spring/summer rainy mudholes at the construction sites. I like being able to park & unhook it to use my truck for other needs. Hope this helps you ponder what you want & need to compliment your operation & to go mobile.Denny Attached ImagesComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:york thats a nice set up
GMT+8, 2025-12-23 21:38 , Processed in 0.080353 second(s), 18 queries .
