查看: 13|回复: 0
2 ton chain hoist rebuild
发表于 2021-9-1 00:03:02 | 显示全部楼层 |阅读模式
A friend is moving out to college. he was selling some stuff and giving away junk too. he left me with a 2 ton chain hoist. the hoist didn't turn due to being filled with nuts and other crap from mice nests. Filled it with greese after i cleaned all the gears of with wd40Oh, denrep, I didn't have any $1s for comparison, so I used a ten.
Reply:I love restoring old tools, After its working put some nice paint on it and it'll be good as new.
Reply:Nice score. Amazing how old stuff can be kept alive and new expensive crap is just crap.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Look for lube holes on the main gear wheel.  Easy to overlook.  It's on the hubA drop of Chain LUbe, or motor oil wil lubricate the shaft.Gunk MOtorcycle/equipment chain lube is pefect"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I jammed grease into every notch. right now I can give the main wheel a spin and will keep spinning for about 2 more seconds. the main problem I'm working on is mounting it. as the garage roof isn't strong enough. I might be able to make some type of portable crane, kinda like a engine hoist.
Reply:Hey that is super cool!  What a find!    Nice work, man.Have a Jeep Cherokee?  Click Here!
GMT+8, 2025-12-23 23:20 , Processed in 0.066123 second(s), 18 queries .
