results from the first week of the new sem.
发表于 2021-9-1 00:03:01 | 显示全部楼层 |阅读模式
All stick, first set is 7018 1/8" 120 amps vert. up V groove. secound batch is simular to the first but it started as open back v with 6010 1/8" at 80 amps than a hot pass at 90 and two 7018 filler passes. than I started to cap it but I had to clean up, and was going to put one more stringer on the bottom plate. And Mods I am sorry that I posted this in the wrong listing please move if needed. Attached ImagesLast edited by violatedppl; 01-30-2008 at 02:16 AM.
Reply:Just remember to pause on the sides during the weave, and change the electrode angle slightly so that it angles towards the faces of the bevel, instead of straight on.  Failure to do so will result in undercut and cold lap crevices that just love to trap slag.
GMT+8, 2025-12-23 21:41 , Processed in 0.106903 second(s), 18 queries .
