penetration dumb question
发表于 2021-9-1 00:02:56 | 显示全部楼层 |阅读模式
Okay so dcep has the most penetration.. AC about 50/50 (cleaning and pen) and Dcen has least penetration correct?? So heres a question how come... Is it correct that negative ions create the cleaning action and positive the penetration( or vice versa) I know dcep 70% of the heat is on the rod and EN 70% is on the metal.. OKay so scientifically how come diff polarities have diff penetration?
Reply:Read this then ask your question.http://www.weldingweb.com/vbb/showthread.php?t=18720David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Well I am talking about SMAW.. Im just curious as to 70% of the heat on the filler metal(dcep) pentrates better than 70% on the base metal(dcen)? Maybe its simply because 70% of the heat on the base metal is distriputed and does not allow as much penetration?
Reply:Yes in Stick and mig dcep gives max penetration. In TIG DCEN gives max penetration and DCEP gives cleaning action. --Gol'
GMT+8, 2025-12-23 21:41 , Processed in 0.074743 second(s), 18 queries .
