Need help w/ Dial Arc 250 HF-P Aluminum setup
发表于 2021-9-1 00:02:52 | 显示全部楼层 |阅读模式
I have a Dialarc 250 HF-P, with the Mic 4 inverter, and a tig torch with thumbslide, I've been using it to stick weld and it runs fine, but I'd like to try and weld  aluminum tig with it, nothing major , just practice and play with it, I work at a local marina and there is demand for aluminum repair, just small stuff, any advice would be greatly appreciated, thanks.
GMT+8, 2025-12-23 21:41 , Processed in 0.094261 second(s), 18 queries .
