Just getting into some projects
发表于 2021-9-1 00:02:48 | 显示全部楼层 |阅读模式
Here's a small welding table I'm going to build for my small garage. Have some old chain link fence posts & rails laying around that will make up the legs and rack at the bottom. Table will be 48"L x 30"W x 36"H. I plan on a 1/2" for the top on top of 2x2 sq tube. There's 2 ground lugs on the bottom longitudinal rails. I might put expanded metal over the lower area.My welder cart I finished back in the spring. Converted from a tool box I got off craigslist. It rolls fine from the shed to the driveway & garage. Will be moved to the garage when I finish getting it set up.Freedom of speed
Reply:Rogerc said"Have some old chain link fence posts & rails laying around "Nice looking bench and cart roger. If those posts are galvanized be careful of the fumes when welding,EXTREMELY toxic and as you likely already know there is no cure for death.FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Originally Posted by Felonyass MonkRogerc said"Have some old chain link fence posts & rails laying around "Nice looking bench and cart roger. If those posts are galvanized be careful of the fumes when welding,EXTREMELY toxic and as you likely already know there is no cure for death.Felon
Reply:I LOVE the tool box cart!  What a great idea!  * Gears turning... *Have a Jeep Cherokee?  Click Here!
GMT+8, 2025-12-23 23:20 , Processed in 0.097558 second(s), 18 queries .
