battery mount and
发表于 2021-9-1 00:02:44 | 显示全部楼层 |阅读模式
battery mount and a place to put the chains Attached Images
Reply:Looking great, the battery mount is for your winch which also goes in the reciever of your truck correct?
Reply:This might be a dumb question, but how did you cut out the angle iron to make this kind of cut? Attached Images
Reply:guessing he used the cutoff tool in one of the pics
Reply:Originally Posted by grphxThis might be a dumb question, but how did you cut out the angle iron to make this kind of cut?
Reply:Ah makes sense.  I'm so use to using my plasma cutter to cut everything.  When I make brackets and boxes with angle iron, I usually cut the angle iron at a 45° and buttweld it but your method looks a lot cleaner.
Reply:i used a die grinder for that if i have more than that i use my plasma cutterthe two air tools i use the most are die grinders Attached ImagesLast edited by ed mac; 11-20-2009 at 10:32 PM.
Reply:I use them too. They are dangerous little flickers of crap into the face and eyes. Goggles and Faceshields only protect so much. Now I use a full leather welding hood with a clear lens in it for using those tools. Just a thought. It's not cheap, but neither are my eyes. I have two now. One for plasma cutting and one for cutting/grinding.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Just a thought. It's not cheap, but neither are my eyes. I have two now. One for plasma cutting and one for cutting/grinding.
Reply:I had FOUR!Everyone called me four-eyes because of my glasses.Then my wife bought for my birthday a lasik eye surgery. It was awesome. And I can see 20/20 and no restriction on my driver's license. It wasn't cheap. That's why my eyes are worth more now then when I was born. They have been upgraded!!!!HA! You thought you had me, didn't you! Get up earlier next time!Take care guys. Off to bed for me now.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-23 21:36 , Processed in 0.072697 second(s), 18 queries .
