well here goes
发表于 2021-9-1 00:02:39 | 显示全部楼层 |阅读模式
I have used a tig welder before and got quite good at welding with it. I left the place that had it and all I know is it was a Lincoln square wave tig welder. 2 years later now I am looking to get a welder and could really use some help. I would be using it around the house. Welding alumn, steel and stainless. I don't think I would be using it for anything bigger than building a motorcycle stand. I know nothing about a mig other than you need to change the spool to weld a different metal. I might not even know that! I was thinking of the Lincoln 225 but wonder if something a little less $$ might work as well. I know some of you might not  like questions like this but any help would be appreciated. I know just enough to be dangerous right now.
Reply:its gona  start with what you can afford:::new/or usedbuy used: if you can try b4 you buy maybe some thing along the thermalarc, have heard some good things on them i use an Idealarc 250ac/dc tig, its been very good to me ...but look in the budget to get startedothers will chime in on this    GOOD LUCK shop smart
Reply:I sent you a PM and welcome to the forumsMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:The Thermal Arc Arcmaster 185 would be Ideal for you if you have or can install a 220 outlet.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
GMT+8, 2025-12-23 21:38 , Processed in 0.091611 second(s), 18 queries .
