What is this welder worth?
发表于 2021-9-1 00:02:38 | 显示全部楼层 |阅读模式
It is a Lincoln 300 idealarc 300 amp tig welder for sale on e-bay. here is the link Also is this a good welder for someone who has never tig'd before? i have mig welded and stick welded, but i am lookin to get a tig welder would this be a bad choice?ThanksJohn
Reply:Yes, it a good welder, but the link did not show up on your post.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:It's big.  If you have the room, the power and can do a local pickup go for it.  Hard to estimate a value but for me $500 - $600 would be my personal limit. 150 to 250 may be a better range.  There was one sold at an auction here and went for around 800.  If you would have to ship it my advice would be forget it.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Also look at the phases required. You find a lot of those big old machines on ebay for cheap. The reason they are cheap is because they require 3 phase power which most don't have access to.The difference between art and craft is the quality of the workmanship. I am an artist.
GMT+8, 2025-12-23 21:38 , Processed in 0.095202 second(s), 18 queries .
