Electric Stove
发表于 2021-9-1 00:02:28 | 显示全部楼层 |阅读模式
Here's my modified stove.  Turns out that we should have removed the elements (they dont work so well anymore) before trying to widen the opening from 21" to 24". With a little more hammering, the door shut just fine and now it sits under my table(had to lift the table with the forklift to slide it in there). Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Why do I get an image of you basting this engine block?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Originally Posted by NiteskyWhy do I get an image of you basting this engine block?
Reply:Originally Posted by DSW Reminds me of having to fill the battery cells on the track loader on a job site. The laborer came back with a turkey baster from the store to fill the cells up with. Probably the best thing I've ever found to put water in large battery cells!
Reply:Plus the oven's self cleaning!
Reply:now  for the... cam-berry sauce,crank-stuffing, an piston-piegood job with the BFHidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by prop-doctornow  for the... cam-berry sauce,crank-stuffing, an piston-piegood job with the BFH
Reply:ok ok broccoli1  we can change the menu  may be some  wobble-stick-stuffing   idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
GMT+8, 2025-12-23 21:37 , Processed in 0.389738 second(s), 18 queries .
