Custom headers for my race car
发表于 2021-9-1 00:02:24 | 显示全部楼层 |阅读模式
Well, just for the heck of it, here's a project from a few years back.  I've got a '67 Olds Cutlass with a small block Olds engine.  Would seem like an off the shelf header would fit, not for a small block. Only big. So here are some pictures.Please bear in mind this was my first set of pipes, I used a 110V mig, and I am an amature.
Reply:Sorry the pictures didn't load trying again. Attached Images
Reply:looks like you had to get creative on a couple of those pipes.  looks like each header has a removable primary.  Was that to aid in installation or was it necessary to fit around some component?
Reply:Left side had to go around the steering column. And to keep equal length primaries one on each side went around the frame rail.
Reply:Here's a shot of the drivers side in the car. Attached Images
Reply:Originally Posted by OldsculeLeft side had to go around the steering column. And to keep equal length primaries one on each side went around the frame rail.
Reply:Originally Posted by mavman4 Where do you race?  So far, I have only raced at Famoso raceway North of Bakersfield.Tom
GMT+8, 2025-12-23 23:18 , Processed in 0.075113 second(s), 18 queries .
