Welding in Magnetic Fields
发表于 2021-9-1 00:02:16 | 显示全部楼层 |阅读模式
i m welding water heaters, when torch is close to the end the arc deflect.i think that is for magnetic field in .some one told me that i can change from DC to AC, to dissmiss this problemWhat parameters i need to change? filler metal, flux, voltage, current?welding parameters are:travel speed 100 in*mincurrent 34-35ampvoltage 21-28 voltsfeed speed 94 in * minbase metal 1008 1.5 mm thickness
Reply:Sounds like arc blow/wander, it's when the arc doesn't take the shortest path between the electrode and the workpiece.AC recduces this but sometimes not completely. There are other steps but i don't have details, something like changing the return lead point and such...Metaltrades.co.uk
Reply:moving the work clamp to the opposite end of the weld where the arc blow is happening sometimes works. clamping closer to the weld sometimes works. using 2 clamps on either side of the weld sometimes works. also make sure your leads are not laying parallel to each other, separate them or cross them over each other like an X. All stuff out of the book. AC works as a last resort. but I guess that would depend what process your using?I like to party!
GMT+8, 2025-12-23 21:40 , Processed in 0.093945 second(s), 18 queries .
