Some Mig From Welding Class
发表于 2021-9-1 00:02:14 | 显示全部楼层 |阅读模式
Just some practice beads we had to run. I tried different methods likeCCCCCCCCCCCCC/\/\/\/\/\/<<<<<<<<<All seemed to work about the same.Any input appreciated.I'm 21 and learningAvid 4wd enthusiastASE Master tech (Automotive), mechanic/fabricator by trade
Reply:hard to really see what you've got there.  Would be better if you had just straight lines instead of the "lattice work" that you have there.  I'm not a pro by any means, but it looks like you've got a lot of build up and not so much penetration.  What heat and speed are you running???
Reply:Making your own diamond plate? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Heat was 3/4, and speed was around....6 I believe.Tanglediver, we have to make our own diamond plate now, Budget cuts really kicked in this year!I'm 21 and learningAvid 4wd enthusiastASE Master tech (Automotive), mechanic/fabricator by trade
Reply:You make your own waffles too?  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Looks awfully humped up from what I can see.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:What thickness material???  Again, I'm not a pro, but it looks like it needs more heat and/or less wire speed... but I would ask the pros around here...
Reply:I would say about 12 gauge steel.  I made the beads wide like that on purpose, it was flowing well.I'm 21 and learningAvid 4wd enthusiastASE Master tech (Automotive), mechanic/fabricator by trade
GMT+8, 2025-12-23 21:36 , Processed in 0.092310 second(s), 18 queries .
