torch for sync 200
发表于 2021-9-1 00:02:10 | 显示全部楼层 |阅读模式
just curious what the best water cooled torch for a syncrowave 200 would beMiller Bobcat 250MillerMatic 250 w/ SpoolgunMiller Spectrum 623 X-tremeMiller Regency 250 /SpoolgunComplete Machine Shop
Reply:The 18 series torch will take the same parts the 17 series torch that came with the machine will. Personally I like the 20 series torches better than the bigger 18 series ones the tech school has.How much you have invested in parts for your existing torch and how small and maneuverable you need the torch to be will play a part in this. It would be a toss up for me which way I'd go. I've got a ton of 17/18 series parts, but not a lot of 20 series parts. I do like the small compact 20 series torch better, and all else aside, that's the way I would go. Probably look at a CK torch that would match up to a 20 series torch rather than the Weldcraft ones. ( can't remember the model number right now).  IIRC the CK torches have a higher duty cycle rating..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I got a ck 225Sf fx http://www.arc-zone.com/index.php?ma...oducts_id=7614 and that torch is awesome. A lot more comfortable to use than the weldcraft cs310 it replaced.
Reply:I got a chinese knockoff WP-20 on ebay for cheap. It's awesome.Welding/Fab Pics: www.UtahWeld.com
Reply:I say best bang for the buck, easy to find parts for and small/comfortable, the wp 20......Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Some of the Binzel line up seemed alright.  But I can't really find them anywhere.I will be purchasing a WT-20-12R which is a weldtec unit.  Just need to spec out a water cooler first since that is spendy.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:thanks for the info im going to have to rig me up a coolant system alsoMiller Bobcat 250MillerMatic 250 w/ SpoolgunMiller Spectrum 623 X-tremeMiller Regency 250 /SpoolgunComplete Machine Shop
GMT+8, 2025-12-23 21:36 , Processed in 0.091282 second(s), 18 queries .
