can crushers???
发表于 2021-9-1 00:02:04 | 显示全部楼层 |阅读模式
Anyone made or have design for a cool can crusher? I go through lots of "beverage cans" when working after hours in the shop. I've seen the cheap plastic ones, but would like to fab a killer crusher. Can't seem to think of any cool designs that would be simple enough to be practical, maybe its all those beverages?Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Here is a link to one that was posted some time ago.http://weldingweb.com/vbb/showthread.php...hlight=crusherHe has a shopping list and all.Looks simple to make.
Reply:Here is one I made. It is not cool but works.http://weldingweb.com/vbb/showthread.php?t=23249
Reply:I have a vision of building a can crusher that works like a wringer...  dump a bucket full of cans in a hopper which feeds them to a pair of flattening rollers driven by an electric motor with either a gear train or chain and sprockets.I haven't built it yet, but I'm going to when I get aroundtoit.  - MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:I've been playing around with air cylinders lately and when I get time I will make an air can crusher.  Just need a peice of pipe and cut an opening for a can to fit and weld a peice of plate on one end and attach the cylinder to the other.  Add a valve and drop a can in and hook it up to your compressor and watch the cans get crushed.  Easy to build and a fun toy, just be careful where you stick your fingers!  Search youtube for can crushers and you will get all kinds of ideas.Here is an air one[ame="http://www.youtube.com/watch?v=8uJmj9x3uFA"]http://www.youtube.com/watch?v=8uJmj9x3uFA[/ame]Here is another pretty neat one.[ame="http://www.youtube.com/watch?v=ZpDtn23SEio"]http://www.youtube.com/watch?v=ZpDtn23SEio[/ame]
Reply:Great ideas but after further thought I think I want to build a crusher that will handle a twelve pk.. When crusher is full, (12 cans), it cycles, crushing all twelve cans but in a way that links the cans together, forming a single sheet of aluminum. It will probably be a while to manifestation.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:anyboby now where to get the plans for the second can crusher
Reply:where did you get the air cylinder
Reply:I've bought a bunch of air cylinders off ebay for some projects.  Another good source is www.surpluscenter.com.
Reply:Haha... I like that second one.. Hook a starter motor to it and you'd be cookin'.Common sense in an uncommon degree is what the world calls wisdom.
Reply:oh... oh.... perfect opportunity to use lmgtfy.comhttp://tinyurl.com/ycwz35l
Reply:Originally Posted by BrainfarthHaha... I like that second one.. Hook a starter motor to it and you'd be cookin'.
Reply:my uncle built a really nice one out of lexan and steel, it had a lexan chute, and was powered by an air cylinder, the cool part was it had an Allen Bradley photo eye that saw the cans as they dropped, then it crushed them
Reply:Check out the Ez Power Crushers.  There is a complete (compressed air/pneumatic) powered crusher or a DIY version (steel, mountable body).  The DIY gets you part of the way there... you just need to add some type of power (e.g., an air or electric cylinder) and what ever other customizations you want (multi-feed, auto-activate, etc).www.ezpowercrusher.com
GMT+8, 2025-12-23 23:09 , Processed in 0.087424 second(s), 18 queries .
