wood stove refurbish and welding
发表于 2021-9-1 00:02:03 | 显示全部楼层 |阅读模式
I have a wood stove find ( garbage pick ) and it is missing number  16 and number 15 in the picture    cook plate and vent ring? I  priced replacement parts  and they would be close to  $200 shippedI want to weld mild steel plate over the hole and weld a vent pipe fitting directly where it vents.the stove will be in a detached garage and on a concrete floor and vented properly  used for those winter projects when i don't want to freeze.I does not have to be bullet prof or very pretty  just airtight and safe enough for the location will i get acceptable results with my arc welder!it is cast iron can i use 1/8 steel or less for the patch?if all goes well i will post weld and stove paint rebuilt pictures.Thanks JR Attached Images
Reply:This will be a nice easy project. The big thing will be to not warp the chimney ring welding it together. Just cut a circle for the lid, and weld up a bolt on chimney base ring. just copy the cast parts. the lid doesn't have be tight, it just sits there, you would be unhappy with a welded in lid, it is much better to be able to open it. , the chimney base can be bolted on and sealed with some fiberglass roping, (just roll up some fiberglass cloth and lay it between etc).  The old stoves were all bolted because it worked, No use reinventing the wheel.  Don't expect it to be real airtite, very few of the cast stoves were.      Nice little stove, a friend heats his trailer house with one.past work toys; lathes,mills, drills, saws,  robots, lasers ironworker, shears, brake, press, grinders, tensile tester,  torches, tigs, migs, sticks, platten table, positioner,  plasmas , gleeble and spot. Retired June 30, 2009.
Reply:they wont need to be welded, make them a snug fit an they will carbon up/sealthe cook top plate was made to come off to add woodthe flute will sutt/carbon up also use 1/4 or 5/16  or thicker if you canbolt the parts that can be boltedidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Hi guys I never thought about  bolting it  down for some reason  that is the way the  original vent was attached and will be much easier to do.and if I find heavy enough steel  i will  just drop in the cook plate piece.  it looks  like the diagram right now because i took it apart.ill have to find some fiberglass rope for the seams.Thanks
Reply:Your can also get high temp silicon caulk to seal around the flue/stovepipe and any other part you want sealed.  I just installed a wood stove in my shop and the stuff works quite well.You need to get the correct gasket rope - not fiberglass which will burn up quickly.  Check with wood stove dealer or hardware store (not Lowes or HD).  Also, as I recently posted, check craigslist for stove pipe/chimney pipe - will save you BIG $$$$.
GMT+8, 2025-12-23 23:29 , Processed in 0.095254 second(s), 18 queries .
