Dockson torch
发表于 2021-9-1 00:01:55 | 显示全部楼层 |阅读模式
Hi all, Does anyone know anything about these torches besides it old?I hooked it up and it was leaking through the oxy lever fitting.There is a pin,spring,"cup","bowl" set up.The question is ...Is there "O" rings that go between the cup and bowl or is that carbon build-up?I see alot of carbon in that chamber and that is what got me thinking.(and also got me thinking flame arresters).Can anyone help?Thanks,DDOGIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Originally Posted by ddogHi all, Does anyone know anything about these torches besides it old?I hooked it up and it was leaking through the oxy lever fitting.There is a pin,spring,"cup","bowl" set up.The question is ...Is there "O" rings that go between the cup and bowl or is that carbon build-up?I see alot of carbon in that chamber and that is what got me thinking.(and also got me thinking flame arresters).Can anyone help?Thanks,DDOG
Reply:I got them to quit leaking for the most part I did find that the rubber seat was not square and flat I fixed that problem now it comes out around the pin when the oxygen lever is depressed.I have looked all over the net trying to find parts and nothing.I just appreciate my buddy for loaning them to me and was trying to fix them for him in the process.They look like a good heavy duty set of torches it's a shame you can't get parts anymore.Thanks,DDogIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
GMT+8, 2025-12-23 23:30 , Processed in 0.086578 second(s), 18 queries .
