Pins for hanging signs
发表于 2021-9-1 00:01:52 | 显示全部楼层 |阅读模式
I am going to hang some laser cut letters ( business name).The letters are made from aluminum and need to be set off the wall 5/8 of an inch.I have used drive pins for:confused steel ones in the past. I can just tap on the sign with a hammer but that isn't going to work with  aluminum.Has anyone done anything like this or have any suggestions?
Reply:what kind of wall/surface are you mounting it too?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:They are cement block pillars covered with tile.
Reply:You could drill and tap a shallow hole in the back, screw in a piece of all thread or a stainless bolt, then drop them into holes in the concrete and secure with some RTV or Epoxy.Arclight Originally Posted by kmfdm242I am going to hang some laser cut letters ( business name).The letters are made from aluminum and need to be set off the wall 5/8 of an inch.I have used drive pins for:confused steel ones in the past. I can just tap on the sign with a hammer but that isn't going to work with  aluminum.Has anyone done anything like this or have any suggestions?
Reply:Since you need to hold them off the wall anyways, I'd think about welding some sort of stud to the back of the letters ( I'm assuming from your post you don't want the fasteners to show from the front). I'd either machine a step in the post so the step is 5/8" off the back of the letters or weld a washer on to set your spacing requirement. The rest of the post will be what attaches it to the wall. Hilti makes an epoxy for setting anchors. Drill a hole slightly bigger in dia to your post, fill 1/2 way with the epoxy and then insert the post in the hole and brace and hold until the epoxy sets.I'm sure I could come up with a more complicated solution that would allow you to use other types of fasteners, probably some sort of bracket you attach to the wall and then hang the letters from the bracket and secure them, but I think the epoxy method is probably the easiest..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:You can use 3m VHB tape to hold the sign to the offset posts or brackets if you don't want to weld them to the sign.If you want to use posts then counter sink the end, put the tape on the Post and then attach the Sign.http://www.rshughes.com/catalog/3517...FWg0Qgoddg_S_QI've ordered from here- we attached a sheet of 20g SS to a regular steel door for our Entrance.Once this stuff is on, it is on.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:that 3m VHB is no joke.      Thats some incredible tape.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I once got to visit a fleet customer.  They were making small transfer buses, the kind of thing you see at the airport.  They used the double sided 3M tape to secure the aluminum skin to the framework of the vehicle.  No welding, no screws, no rivets.  Just tape.
Reply:and a good seam with a weather tight bond to 200 MPHVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-23 23:29 , Processed in 0.069209 second(s), 18 queries .
