Issues with my TB 302
发表于 2021-9-1 00:01:46 | 显示全部楼层 |阅读模式
The other day my TB 302 started acting up, I am hoping someone here might have some answers. The welder welds fine but if I turn the ignition switch to RUN it stays at low idle. I can't check the hours either. when I put it in the RUN position it shows the hours till oil change. I can't reset the hours till oil change. Everything else seems to work fine. Any help will be greatly appreciated.
GMT+8, 2025-12-23 23:09 , Processed in 0.074867 second(s), 18 queries .
