Ornamental Iron door knocker
发表于 2021-9-1 00:01:45 | 显示全部楼层 |阅读模式
I'm trying to think through a personalized wedding gift idea of fabbing up a nice wrought iron project that includes scrollwork of the couple's last name.  What do you think of some kind of door knocker along those lines?  Maybe 12 - 14 inches diameter with the last name initial and a knocker that could be hung on a front door?  Anyone got any thoughts on this one?  I really want something to incorporate the initial in it - doesn't have to be a door knocker...
Reply:Sounds good, IF it goes with the theme of their home.  Some new modern homes/entries would look awkward with ornamental iron, especially one that size.  A lawn ornament could also work, as could a house number placard.
Reply:If it's a single home that they live in, maybe a personalized Mailbox.
Reply:Actually, right now they are in a rental home and are looking for a home to buy.  That's why I was thinking of something to simply hang on a door.  I don't think something about 12" diameter would look overbearing regardless of the house...  But, that's why I'm bouncing ideas off yall...  So, keep the suggestions coming!Thank you!
Reply:Take a look at their porch light.  If it's mounted on the outside wall, as opposed to an overhead, you could make them a personalized 'designer plate' that would be sandwched under the mounting.Take off the light, disconnect the wires, slip the plate over the wires, reconnect and replace the light.Take a que from those medallions that are used on ceiling fans/lights.This could be taken with them wherever they go.
Reply:Maybe a sundial with the initial in the middle. They could put it out front for decoration, or put it in the garden when they get a new place. Probably don't have to be as concerned if it doesn't match the house.
Reply:I would shy away from a knocker, I think a 12" dia one would look pretty out of place on most any house except for the adams family.  I like the idea of a lawn ornament or house numberHave we all gone mad?
Reply:how about a candle holder something like this but using their initials in metal as the base.Felon Attached ImagesCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Do they have a fireplace?  A fireplace screen would be nice.  Lots of room to work with.Hey, you know a guy that makes a mean pot rack, he can help you out...
Reply:I dig that sundial idea.  Might have to do one for myself!
Reply:Anymore, from a security standpoint, it's not recommended that you put your last name on the mailbox or door.  Makes it too easy for some scumbag to get your name and house number and get a phone number to check if anyone is home.
Reply:Well, I ended up doing more of a lawn / front yard deal.  It has thier initial and the house number on it.  I made the house number plate so it would just take adhesive numbers so they change it when they move.  It's a combination of 1/4" round bar and 1/8" x 1/2" flate bar.  To finish it I bead blasted it then painted it hammered black.  It's hard to beat Hammerite for stuff like this! Attached Images
Reply:Looks nice.  At first I didn't see the initials, thought there was supposed to be 3 of them and was wondering if the pic was reversed.  Now I see it's the letter 'M'.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Looks good.
GMT+8, 2025-12-23 23:29 , Processed in 0.146120 second(s), 18 queries .
