four wheeler brake drum cover repair
发表于 2021-9-1 00:01:38 | 显示全部楼层 |阅读模式
hi new to this fourm. this is the brake drum cover off my four wheeler. the wheel bearing went and the seal cover cut into the cover. the metal was very thin so brazed it.Comments welcome but take it easy its been a while since i brazed anythig. Attached Images
Reply:I'm not much of a brazer but it looks good to me!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Wow, that's a lot of Bronze !  OXY / ACE and 1/8th LFB ?Looks like it's laid in there beautifully.... Nice looking Braze.Cheers,/Jman..Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Thats the best looking brazing I have ever seen. -DanOwnerDW Metalworks LLCMiller Trailblazer 302Miller 8RC FeederMiller Passport PlusMiller Dynasty 200 DX W/Coolmate 1Hobart Handler 135Hypertherm PowerMAX 30Smith O/A Torch SetPlus much much more
Reply:Wow! that is a lot of material.
Reply:Wow how big was that crack? did it go all around that hub? good work on the brazingCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Awesome brazing job, but I'm curious, did you use positioner or turntable while brazing to get that so uniform? Again, beautiful job.
Reply:WOW Nice brazing job.  Did you happen to use a TIG torch or Oxy Acetlyene on that?Century Powermate 100 ( my first welder)Lincoln Precision TIG 185
Reply:thanks for the comments  the crack was almost all the way around and was about a sixteenth wide. I used a oxy acetlyene torch i never used a tig welder before.I didnt use a positioner i did three stop and starts.
GMT+8, 2025-12-23 23:11 , Processed in 0.068101 second(s), 18 queries .
