Mig welding aluminum withOUT a spool gun?
发表于 2021-9-1 00:01:29 | 显示全部楼层 |阅读模式
I want to weld some aluminum, probably nothing thicker than 1/8th for now. I have a Miller 175 mig machine, but the spool gun is over $600 (while the spool guns for the new 180 is less than half that ). I would buy a new tig machine before I'd pay $600 for a spool gun. The purpose of the spool gun is simply to get the wire closer, because aluminum wire is too soft to push through the normal mig lead, correct? If so, has anyone even tried with a normal mig lead? It seems like if you were very careful to keep the lead as strait as possible at all times it might feed. If any one has tried what was the result and what thickness of aluminum wire were you using?Also what thickness can I expect to be able to do with my MM175?
Reply:It can work sometimes, you need to use an aluminum only liner so that it does not get contaminated by the steel wire.  It would also help to get a shorter lead so it has less distance to push.Its more commonly done in a push-pull gun, with rollers at the gun and wirefeeder. I dont know if they make one that will work on your unit, but its something to look into.Have we all gone mad?
Reply:I have done it, but it is a PITA!  Do what you have to but be patient with it. You will also go through some tips like that. Good luck.
Reply:Looking at the specs, you probably will be able to do 1/8", possibly 3/16" alum.I looked at the Spoolmate 100 and the Spoolmate 3035,  The pin connections to the machine look to be the same for the gun trigger and the feed power but the part numbers for the motors are different. I don't know if they are using a different voltage to run the motors or if it's just that they have superceded one part with another. You might PM Steve (7A749) or may be one of the other guys here who works on Miller stuff and see if they know what the actual differences in the guns are. It may have more to do with the machine hookup than the spoolgun. I know I had to install an adapter kit from  Miller in my MM185 in order to run the 3035 spoolgun on my machine. I forget now exactly what was involved in doing so..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I have done without any issues on my Hobart Handler 140.  i just changed my spool over to AL...then changed my gas over to 100% Ar.....and away I went!  No birdnesting, just ugly aluminum welds!  nothing a grinder couldn't make look decent though.my gun lead on my HH140 is short though.....10 feet or maybe even 8 feet long.
Reply:Originally Posted by BurningMetalI have done without any issues on my Hobart Handler 140.  i just changed my spool over to AL...then changed my gas over to 100% Ar.....and away I went!  No birdnesting, just ugly aluminum welds!  nothing a grinder couldn't make look decent though.my gun lead on my HH140 is short though.....10 feet or maybe even 8 feet long.
Reply:Originally Posted by silverram323Thanks, by reading this i will try it myself, almost everyone says to buy a spool-gun.  They are 1/2 price of the welder.
Reply:i checked into fitting out my mm175 with a spool gun and decided that the money and bs would not be worth it and the fact that taking anger meds and since i'm already on blood pressure meds the mm252@30A spool gun were better spent. i have to say that since i got the 252 @ 30A i haven't welded 5' of aluminum beads with it. i use the tig or the O/A torch.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:I am still a total noob even with MIG welding steel, but hope to get into aluminium welding eventually.Has anyone here tried to BUILD a home made Frankenstein spool gun out of an old salvaged wire feed motor ?  The prices that spool guns go for is absolutely obscene.I am, sure with a few parts from a deceased MIG welder, and a bit of imagination, plus a couple of boxes of crazy pills medication,  it should not be all that difficult to bodge up something that can imitate a real spool gun ?Cheers,  Tony._________________________________Transmig 310 + Argoshield LightOxy acetyleneOxy propanePrehistoric stick welder_________________________________
Reply:Originally Posted by DSWHave fun. I'd suggest you talk to your doc about some tranq's and probably some blood pressure meds.
Reply:Originally Posted by WarpspeedI am still a total noob even with MIG welding steel, but hope to get into aluminium welding eventually.Has anyone here tried to BUILD a home made Frankenstein spool gun out of an old salvaged wire feed motor ?  The prices that spool guns go for is absolutely obscene.I am, sure with a few parts from a deceased MIG welder, and a bit of imagination, plus a couple of boxes of crazy pills medication,  it should not be all that difficult to bodge up something that can imitate a real spool gun ?
Reply:Hey guys,I see this query quite a bit & there is a really simple & inexpensive solution. I have a 160A MIG unit that is setup strictly for the alum. production runs I do(150deg.). The wire feeds easily with no issues such as birdnesting. If you feel that a spoolgun setup is too much to invest in for just a few alum. jobs once-in-a-while, then consider getting another complete MIG cable assembly for your unit. These can generally be found on E-Bay quite reasonable.If you are not experienced enough with modifications or have the tools to shorten a MIG cable assem., take it to someone who is. It would be much easier to do the machine side of the assem. rather than taking the gun all apart & attempting to get the internals in the exact configuration for proper function. Then you will have a nice, short cable assem. that is easily changed over so you can do aluminum. Just some mental fodder to digest...... Here's a pic.....Denny Attached ImagesComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:For the price and free shipping I would order one of these and figure out how to make it work on mine, doesn't look like it would be too hard.  http://www.ebay.com/itm/NEW-Hot-Max-...item3a6cd1d32f Otherwise the Spoolmate 100 sells for $200, and it looks the same as my 3035, might have a back end that you have to modify to make work on yours though. With the addition of a SGA 100c you can make a spool gun work on just about anything too.
Reply:MIG guns can be shortened and Teflon liners aren't expensive. I shortened a used Tweco easily enough, but the project it's for didn't happen so I haven't got to use it yet.http://weldingweb.com/vbb/showthread.php?t=43695I'd grab a used gun off Ebay and have at it, or get with OADoctor about having him circumcise a gun for you. I don't know what size gun the 175 takes, but Miller guns are plentiful.
Reply:I have used my175 for alum with the 10' m 10 gun ,035 wire it works ding have Teflon liner so I had some contamination.  For a little job it works.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:I tried it and it just wouldn't work for me.  I shortened the old GA gun from my MM200 and installed the Teflon liner.  Both 4043 and 5356 fed like a dream.  I ruined 10 tips in 20 minutes.  The wire would always burn back and melt the tip, regardless of stick out length, amps or Ar flow.  I was thinking no pre flow may have had something to do with it.  My Spoolmatic worked fine.  I'm a novice, so YMMV.  Let us know it it works for you and how you did it.  I will try to post my posting on it with pics from 2011.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:http://weldingweb.com/vbb/showthread.php?t=60805TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-23 23:30 , Processed in 0.112329 second(s), 18 queries .
