how to
发表于 2021-9-1 00:01:25 | 显示全部楼层 |阅读模式
My name is jacob and, my question is how do i build an amp control or choke for a homemade welder its puting out like 160 amps and id like not to blow so many holes lol thanks jacrigger
Reply:You don't bother.  For the amount of money it would cost to buy a single transformer, you can offer someone on Craigslist 1/2 the amount and get a decent enough welder.From the buzzing noise modern inverter power supplies make, I would suggest they are running a high frequency chopper circuit to control things.... and banks of big transistors to handle the current.  I suspect that the start and stop nature of welding and the relatively long cable runs (inductance) that you need to design to handle quite a bit of surges in power demand and feedback.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:I have used 3 homemade welders.One was 400 amps.I found a control off of a motor driven welder worked on it all summer never worked wright. I got anther welder it was a millon times better.
GMT+8, 2025-12-23 23:12 , Processed in 0.121084 second(s), 18 queries .
