Tried a little process welding today...
发表于 2021-9-1 00:01:24 | 显示全部楼层 |阅读模式
Tried  to process weld at work today.... Constructive criticism welcome...2" 316  .065 wall Miller Dynasty machine...
Reply:good enough for the girls I go with, but what is " process welding " ? is it like autogeneous welding?Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Was this welded in a purge chamber ? and did you use a scotch - brite pad on it to get shin ? it looks good to me !    ok  it is with plasma or a laser!Last edited by T E B; 01-12-2012 at 07:24 PM.
Reply:Atta Boy !  Looks like you free handed it to me.
Reply:Originally Posted by turkgood enough for the girls I go with, but what is " process welding " ? is it like autogeneous welding?
Reply:Originally Posted by T E BWas this welded in a purge chamber ? and did you use a scotch - brite pad on it to get shin ? it looks good to me !    ok  it is with plasma or a laser!
GMT+8, 2025-12-23 23:11 , Processed in 0.067847 second(s), 18 queries .
