I recently purchased an Esab 203 and saw that there is a digital kit available for it. Does anyone know much about this?Thanks,Jim
Reply:Digital meter kit allows you to see the volts and amps on digital meters. JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases. There all here. :
Reply:Does this give you a more accurate way to set things up. I am having some problems getting used to setting the controls. Most of my past has been with stick and gas welding.Jim
Reply:Not unless you are going by a procedure, with exact volts and amps. JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases. There all here. :
Reply:I thought about putting up a chalk board, recording various combinations and posting results. The readouts would probably give me a better feel and could make the learning curve shorter.JimIf we didn't underestimate how much time it took to get things done in advance we probably would never do anything. |
