As ususal "CART"
发表于 2021-9-1 00:01:07 | 显示全部楼层 |阅读模式
Kinda new here posting, usually just a lurker gathering info and tinkering.I'm most of the way through with a cart I started on last X-mas.  It will eventually hold a Bobcat 225, Millermatic S-52A, and a Giant-Tech 520DThe pictures explain most of it.Ernie Attached ImagesThis cat does it doggie styleMiller Bobcat 225Miller Matic S52ACT520D TIG/Arc/Plasma
Reply:the machine my dad gave me needed some work, and the old cart must have been built while the welder was intoxicated, because it is out of square by more than a half inch.  It has to go for room in my garage / woodshop / metal work shop / machine shop / paint booth / boat building facility.  with all the machines stacked on the new cart it will be able to be winched onto a trailer for easier transport, and less floorspace. Attached ImagesThis cat does it doggie styleMiller Bobcat 225Miller Matic S52ACT520D TIG/Arc/Plasma
Reply:squaring the new top roataing section up. a tube with what I thought was excellent cutting for a porta-band. Attached ImagesThis cat does it doggie styleMiller Bobcat 225Miller Matic S52ACT520D TIG/Arc/Plasma
Reply:The cart is together, I'm not happy with the fit right now, I'll have to cut the top back off and re-do my clamp didn't hold tight enough last night and he said he would be happy with it like it was and I finish welded.  Should have just tacked it and checked it myself.  The top is offset to the left about a quarter-inch.Ernie Attached ImagesLast edited by TopSpin80; 12-13-2009 at 11:12 AM.This cat does it doggie styleMiller Bobcat 225Miller Matic S52ACT520D TIG/Arc/Plasma
Reply:Nice looking cart. I do have a question  a bit off topic........I just bought the same air compressor. Do you run a plasma cutter with it?....If so.....how does it do?Thanks,Timmer
Reply:Originally Posted by TimmerNice looking cart. I do have a question  a bit off topic........I just bought the same air compressor. Do you run a plasma cutter with it?....If so.....how does it do?Thanks,Timmer
GMT+8, 2025-12-23 23:14 , Processed in 0.100901 second(s), 18 queries .
