Horse Feeder
发表于 2021-9-1 00:01:05 | 显示全部楼层 |阅读模式
I'm looking into building the horse feeder below.  The plans recomend using 1" square tubing, but dont indicate what thickness..... would 1/8 be too heavy... would 1/16" hold up to horse abuse?[URL="http://www.omafra.gov.on.ca/english/livestock/horses/facts/06-075.htm"] Attached Images
Reply:i would use the thicker tubing ( build it to last)horses can be rough on anything and the barn yard acid, it will take longer to rotidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Use 3/4 rebar, cheaper and holds up well to horses.
Reply:I think most of the bending occurs when you drop a 1500+ pound bale in there.
Reply:I like the design of the one you found. I was going to build something like this for my 6.http://cgi.ebay.com/Hay-Hopper-Feede...item45efd58af1I liked the ideas of chains, bale can move alittle. I was going to put expanded metal for the tray to catch the drops of hay. I'll let you know what I come up with. Use the heaviest material you can some horses can be rough, but not like cows. Right Sam,lol.Brett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:I would have a problem with the design of that round bale feeder.  I would not put the closed tops on the stanchion.  Too many dead horses from hitting there head right at the poll.  I don't care how friendly the horses are with each other.  Make the part where they put there heads open on top.  Remember a horse can and will hurt themselves in a padded stall.  If you don't know what I am talking about I can take a picture of the ones I use for our horses. I don't have a picture now and I am in Germany so it is a minimum of six hours later here than on the East coast of USA.
Reply:Just got done with a internet search, many to look at. Yes I would be intrested in your pics, when you get a chance. I do agree with you and my horse is the only draft in our bunch. when I build mine it will have a open top/headspace. Just trying to make the best possible from all the ours I've seen. Copy this from that one and this from this one and add this as my own idea.BrettBrett B & B Fabrication and Welding Inc.Spalding, MI.
GMT+8, 2025-12-23 23:31 , Processed in 0.100415 second(s), 18 queries .
