Can this be true?
发表于 2021-9-1 00:01:03 | 显示全部楼层 |阅读模式
I just read an add for the new OSSA Trials bike and in the add they state,    "Cast aluminum parts welded to Cr-Mo" Is that possible?  And how?Steve
Reply:Yep,Check this out:http://weldingweb.com/vbb/showthread.php...losion+weldingBuy American, or don't whine when you end up on the bread line.
Reply:Where did you see the Ad? Some times the actual fabrication gets lost in translation to the Ad company their site doesn't mention welding"Type CR-MO steel tube profile with pipe and bottom made of cast aluminium"http://brewsterwest.com/OSSA.htmlEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:The add is in Trials and Enduro News.  I reread it and it states, "Tig Welded" cast aluminum to cr-mo tubing.  I want some of that rod.Steve
Reply:There is also a new process using wire feed welding aluminum to steel.  Right now it has limited use but as time goes on there will be more.  It requires a specialized power supply and the connection is something like a brazing joint only it is done with a wire feed welder.  It is sort of a cold welding developed by Fronius in Europe.
GMT+8, 2025-12-23 23:15 , Processed in 0.114237 second(s), 18 queries .
