Where to buy Flange Wizard tools?
发表于 2021-9-1 00:01:02 | 显示全部楼层 |阅读模式
Where do you guys buy your FW tools from?I'm looking to buy quite a few bits from them to replace some not so great working equipment of mine, and some I don't have.Looking online some retailers seem not so reliable. If I'm dropping $600+ on tools I want to make sure I get them... lol
Reply:I get them from Amazon!AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:Lol, I saw they're on there... walmart also has someOnly problem with ordering from Amazon is shipping will kill me, since I'm ordering 8-9 things, and just about each one comes from a different supplier :|Last edited by Hass; 01-14-2012 at 01:06 PM.
Reply:air gas sells them.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Gangbox.com or ramweldingsupply.com has what you are looking for
Reply:Originally Posted by slim83ramweldingsupply.com has what you are looking for
Reply:2 hole pins
Reply:Originally Posted by slim832 hole pins
Reply:I'm not sure. I forgot to mention pipefitter.com. They got a whole set of flange wizard tools
Reply:i bought the pipe magician kit off ebay
Reply:I havent used 2 hole pins for probably 8  yrs now all I use is a magnetic flange wizard level and i havent had to fix anything yet because it wouldnt line up
Reply:Originally Posted by spurwelderI havent used 2 hole pins for probably 8  yrs now all I use is a magnetic flange wizard level and i havent had to fix anything yet because it wouldnt line up
GMT+8, 2025-12-23 23:13 , Processed in 0.072100 second(s), 18 queries .
