How Old Is This
发表于 2021-9-1 00:00:58 | 显示全部楼层 |阅读模式
Can Anyone Give Me An Idea Of How Old This Welder IsIt's The One I Use At Work - I Know It's 40+ - Just Don't Know How Much Plus Wired 460V 3Ph - Now I Know Alot Of You Aren't As Old As Me But MaybeYou Have Run Across One Somewhere - One More Thing Has Seperate Wire Feeder60# Rolls Of 045 Solid Wire -   May Not Get Back To You Tonight - Boss Say's It Bedtime - So The Old Man Gota Run Thanks Attached Images
Reply:A quick Google search withamerican cryogenics welderturned up a link that at least one American Cryo model was a re-badged Hobart-built unit.  If you can make a similar connection and get the corresponding Hobart model # (assuming it started life at Hobart - maybe another company?), you might be on your way to some answers.HTHLinc Idealarc 250 / SP130 / ProCut20, Harris Torch
Reply:1973?What do I win?
Reply:OK - Help Me Out A Little How Did You Come Up With This Date
Reply:It looks a bit older than my 1979 version from Hobart. Wild @ssed guess.
Reply:Looks like It is a rebadged Hobart RC-300 and a MC-300 wire feederGoogle it.   Lots of stuff out thereLast edited by Housedad; 01-07-2012 at 03:15 PM.Victor Oxy weld/cut Setup Meco Midget Torch outfitEverlast 2016 250EX & Power Cool W300Lincoln Power mig 210MP  w/amptrol and Spool GunEverlast Powerarc 200 Hypertherm Powermax 45Bandsaw, Lathe, grinders, press, Bridgeport, etc.
Reply:Best I can determine from a quick search is a couple of references to it being made sosmetime in the 1960'sVictor Oxy weld/cut Setup Meco Midget Torch outfitEverlast 2016 250EX & Power Cool W300Lincoln Power mig 210MP  w/amptrol and Spool GunEverlast Powerarc 200 Hypertherm Powermax 45Bandsaw, Lathe, grinders, press, Bridgeport, etc.
Reply:Thanks To All Of You - Will Make Note In Work Log - Thanks Again
Reply:Looks like it is in a lot better shape than mine..lol
Reply:Originally Posted by rickou812Looks like it is in a lot better shape than mine..lol
Reply:at least it says made in USAMiller Bobcat 250MillerMatic 250 w/ SpoolgunMiller Spectrum 623 X-tremeMiller Regency 250 /SpoolgunComplete Machine Shop
GMT+8, 2025-12-23 23:29 , Processed in 0.093793 second(s), 18 queries .
