mig wire burning back to spool
发表于 2021-9-1 00:00:57 | 显示全部楼层 |阅读模式
my lincoln is burning the mig wire back to the spool now when i start to weld. has anyone had this problem and know whats causing it. thanks
Reply:Check the tag end at the spool.
Reply:Sounds like the wire at the spool is grounded.  Like Sandy said, is the tag end of the wire at the spool touching the spool holder or feeder.  Is it a plastic, fiber, or metal spool?
Reply:i had been welding for about an hour with no problems then it just started burning back to the spool. i went to the store and bought another spool and i have had no problems since i changed it out. thanks for the helpLast edited by hytekredneck; 03-02-2008 at 09:32 PM.Reason: misspell
GMT+8, 2025-12-23 23:10 , Processed in 0.064151 second(s), 18 queries .
