Cross-fit exercize gym project
发表于 2021-9-1 00:00:34 | 显示全部楼层 |阅读模式
This was a gym I built a while back for a local cross-fit gym.   They use it for pull-ups and ring exercizes.  It is made for up to 10 people to work out at once.  Dimensions are 16' long x 12' high x 4' wide.  The pull-up bars are all adjustable for hieght in 6" increments, with 4 hieghts available for each bar.  The gym is built in 3 sections that bolt together.  Materials are 2x2x3/16 sq tube, 1-1/4 sched 40 black pipe, 1/4x2 flat bar for the pipe flanges and 1/4" plate for the anchor bases.  All hardware is 1/2" grade-8.All welded joints throughout the project were beveled for complete joint penetration on all sides.  Welds checked by cutting apart 2 test joints.Machines used were the Millermatic 350P in pulsed spray mode with .035 70S-6 and 98/2 gas and the PowCon 300SM with 3/32 6011 and 1/8 7018.The gym.Making the uprights.Tube joints.Pics continued on next post...MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Pipes to flanges, with 6011 & 7018.  My small dia pipe stick beads are not the greatest...Getting ready to deliver to customer.  This customer decided to do the painting and installation themselves.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:nice looking beads... I used to be into the whole ripple look but now-a-days a smooth"robotic" look is what I strive for
Reply:Thanks!I've never been into the 'dimes' look with mig.  I don't do alot of fancy torch oscillation either, mostly just straight and even as I can, sometimes a little weave to wash it in.   I like spray transfer best whenever I can use it.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:NIce beads,  you were not messing around on that!!   That miller looks like it lays`em down with spray!!   Who was the engineer? Did you spec the materials yourself or did you just work to print??Anyways nice work!
Reply:Thanks.Customer had a basic idea of what he wanted and I did the design, materials spec. and fab.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I built a similar setup for a cross-fit gym.  It was only eight feet high and wasn't adjustable.  Looks good.
GMT+8, 2025-12-23 23:30 , Processed in 0.299144 second(s), 18 queries .
