scott gross foot pedals
发表于 2021-9-1 00:00:30 | 显示全部楼层 |阅读模式
need to get a pedal for my syncro they seem to have pretty good price on pedals 159.00 just wondered if anyone has used there pedals before looks to be the same style as the pedal i had on my lincoln correction the SSC are are 178 .00 the 159 are from HTPLast edited by umahunter; 01-18-2012 at 07:34 PM.Reason: wrong name350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Not sure what you mean. I looked on the web site and saw only factory pedals.Ian TannerKawasaki KX450 and many other fine tools
Reply:ok i totally screwed that up there from ssc controls i got them and scott gross control350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-23 23:30 , Processed in 0.089303 second(s), 18 queries .
