Cheap Welding Gear FS in Bakersfield
发表于 2021-9-1 00:00:30 | 显示全部楼层 |阅读模式
Not mine, posted in this forum for SA. Mods feel free to move if appropriate.I bought a HF251 this weekend for cheap from a guy closing out his brother's shop. He had some other gear for sale that i wish i could have bought. Here's what i noted:Miller Spoolmatic 15A/30A (not sure which) with the WC24 control box and ~12 aluminum wire spools - $300LN-25 wire feeder, $300LN-7 wire feeder, $200Several guided cutting torch setups for $100-150. I'm not sure what the trade name is, these were torches mounted on a track was a rack & pinion setup so you could cut long straight lines.Nearly new magdrill with several bits, ~$1000Miller engine drive, Bobcat I think? The prices are from memory and he may take less. Good deal for someone though. PM me and I'll send you contact info if you're interested.
GMT+8, 2025-12-23 23:10 , Processed in 0.332226 second(s), 18 queries .
