Awesome 1968 pipeline welding video...and a question.
发表于 2021-9-1 00:00:29 | 显示全部楼层 |阅读模式
This video is so neat on "how it's done," circa 1968.  Also, it's in color!!!!  Many of you guys may have already seen this, many have not.  Here's my question for you pipeline welders.... Whats changed?  Is it still done the same way with a "tent" over the initial tack weld?Enjoy the video:Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Today large diameter pipe often is done with wire feed automatically.  The example shows flux core wire on the first pass only.   They have little tractors that walk around the pipe automatically welding.  You have welding operators who are certified for the machine process.   After welding inspections now can be done with xray or ultrasound with the record kept digitally rather than on film.  The units I have seen are a tractor unit that walks around the pipe taking pictures.   Each time they do a pipeline they come up with something to make it faster and better.  It all depends on the contractor and engineers.  If you google alaska pipeline inspection-YouTube.also  Pipeline welding Manning Alberta 3 fill pass - YouTube     This was a line that ran through Manning Park to the Westcoast a few years back.Last edited by lotechman; 01-19-2012 at 09:35 PM.
GMT+8, 2025-12-23 23:09 , Processed in 0.260727 second(s), 18 queries .
