Stainless to galvanized
发表于 2021-9-1 00:00:28 | 显示全部楼层 |阅读模式
I'm welding stainless steel #3rebar to a galvanized steel structure what is the best stick welding rod to use? 309-15?
Reply:If the bar is A615, I wouldn't weld to it.  If the bar is A706, E309-15 will work well.  Be sure to grind the zinc off the galvanized piece where you intend to weld./Most rebar is A615 and it is generally not permissible to be welded.  Check with AWS D1.6 to calculate the equivalent carbon content (requires certified material).
GMT+8, 2025-12-23 23:11 , Processed in 0.071366 second(s), 18 queries .
