ln 25 test welds
发表于 2021-9-1 00:00:21 | 显示全部楼层 |阅读模式
Here is a better pic of my first welds with ln25 converted to .035 wire and 75/25. Pretty happy with it, aprox 180 ipm and around 140 amps. Hard to tell amperage as I had to point the gun at a piece of scrap and look away to the machine. Maybe a little cold? Flatter bead if hotter? Beads on left flat were push and the others pulled. Fillet on left was pulled and the other pushed. Thanks,SteveAirco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:Hey, that looks good!
Reply:Those welds look fine. Just remember voltage controls the height and width of the weld bead, wire feed speed is amperage (heat) C-25 is a good mix for all position, just remember that above 21-22 volts with C-25 you can get out of the short circuit mode, and into a globular mode, which you definitely don't want, as it's a very harsh arc, with lot's of spatter.
Reply:Looks better than half the welds I see everyday.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Those are some awesome beads bro keep it up
Reply:I agree, you are on the money there!  Professional looking stuff!Have a Jeep Cherokee?  Click Here!
Reply:Very nice :PMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Mig is sweet.  Nice.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-23 23:29 , Processed in 0.110365 second(s), 18 queries .
