unknow tig torch needs cup?
发表于 2021-9-1 00:00:20 | 显示全部楼层 |阅读模式
i have 3 of these : 1 with 2/32 tung complete needs cup1 with 1/8 tung needs cup1 with 1/8 tung needs back cap and cup dont kno what will fit ?? they are not threaded  like my weldcraft. Attached ImagesLast edited by prop-doctor; 12-18-2007 at 09:34 PM.
Reply:Can you give us a close up of just the head of the torch, that will help.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:i'll try in the morning ..its smooth and has a slight taperit looks like it just pushes on and is held by the rubberhaving a time trying to resize they are either tooo big  or  too smallbut will try thanks
Reply:this appears to be a "visu-weld" torch.  I believe  tec torch from San Diego area.  If no one else has info, I will look at mine at work tomorrow.
Reply:Originally Posted by prop-doctori have 3 of these : 1 with 2/32 tung complete needs cup1 with 1/8 tung needs cup1 with 1/8 tung needs back cap and cup dont kno what will fit ?? they are not threaded  like my weldcraft.
Reply:Could be CK torch, if not I know they make press-fit cups so you may be able to get the parts through them.
Reply:Tweco?  I have a weldcraft at work that looks a lot like that. The end cap is metric but the collet body is the samme as a tweco. acording to my supplier.Last edited by welderman1; 12-23-2007 at 06:31 AM.
Reply:thanks guys will check them all outthe dummies around here (lws) have no idea. no old timers work thereand yes its 3/32,  was just a typo on my partall i use for my welding is 3/32. i have a weldcraft torch. been using it 17 yrs now. just need to get those others useable, they came from the local          vo-tech back in 98-99
Reply:OKIE DOKE:: we found out what it isit's  TEC TORCH MODEL 429  300amp water cooled thanks for the help allnow what to do with them
Reply:send em to me, I am down to only one left working!!!!
GMT+8, 2025-12-23 23:10 , Processed in 0.115549 second(s), 19 queries .
