ER70S-2 mig wire
发表于 2021-9-1 00:00:16 | 显示全部楼层 |阅读模式
I have been messing with This wire for a week or two.  The first time I ran it, I condemed it.  The next time I got it to run, this time I think I am getting the hang of it.  Its for out of position welding.  It has one heck of a thick puddle.  Beads on 1/8" seemed to lay on top.  When I turned the heat up, they fell through the plate and the bead was on the other side.  I settled on 200 ipm, 18.1 volts.  Gas was 92/8. Wire is Spoolarc65 .035.One backhand bead (pull) and one forehand.Last edited by David R; 03-13-2008 at 09:19 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Then I went for the out of position with 3/16" X 5" cold rolled.  I started at 200 ipm, 18 volts and kept turning the wire and volts up.  All short arc with 92/8. Bead is huge for the plate Losing control at 350 ipm 18.5v400ipm and 19 volts.  More than I can handle.Last edited by David R; 03-13-2008 at 09:27 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:92/8 gas at short-circuit voltage levels? What I see, is what I get, I suppose. Nice demo again, David! Thanks!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:nice man...your always dependable when it comes to demos.(and you getting your weaves tighter which is really ALOT better =) )
GMT+8, 2025-12-23 23:31 , Processed in 0.070005 second(s), 18 queries .
